sigwatch
I was disappointed to learn it’s not available on RB hardware. Is there anything similar for RBs? I basically want to determine the logic status of a single on/off signal and have it be logged by the MT.
Ethernet hooked up to a relay (use a dpdt relay to connect transmit to receive and make the port go up) would work as far as hardware goes, but routeros doesn’t log ethernet status changes. If there is a way to log ethernet status changes that would be suitable as well.
Thanks!
