is there any way to disable the
system,error,critical login failure for user … via ssh
error message on the console, as it can be disruptive during configuration work? I know that I can remove specific topics from the echo message, but it seems all options are too wide and would filter out other important messages as well.
Is there any way of just disabling these login warnings from popping up in the console?
Thanks,
Florian
