can it be done?
even there is an option there?
I have read that does not include mipsle
so if I want to cancel the beep,I must remove the speaker?
Thanks ,
can it be done?
Thanks ,
as wiki says RB100, RB500 and Crossroads are not supported.
if you are so experienced to do that, you could remove the speaker but it’s not easy neither recommended (warranty void)
