So today I had to pull apart a LHGGM to get a sim card out. Was not happy.!1
So I made a new 3D printable model for a sim card cradle that allows you to pull it out without tape( etc )..
I have attached the .STL file if you want to 3d print one yourself ( I used a creality S1 PRO on super-quality .12mm ).
I kept a thin mesh of plastic to help hold the card from falling throu.
And the final product so I can remove the sim card without issue !!!
The zip file has the .STL for your editing/printing pleasure !
killersoft_sim_tray_extension_for_mikrotik.zip (18.5 KB)
