I need to know the 450G throughput, and Product specifications says:
(http://routerboard.com/RB450G)
RB450G @680MHz (2 port test) -------------64 byte frames------512 byte frames--------1518 byte frames
IP Firewall ---- Conntrack ------ Mode ------Mbps – Fps--------Mbps—Fps-------------Mbps-----Fps
off ------------ off ------------ Bridging----76.9 —150200-----595.15–145300---------1220.47—100500
on ------------ off ------------ Routing----52.38 —102300----396.08—96700----------1035.88—85300
on ------------ off ------------ Bridging----44.95 —87800-----353.08—86200----------947.23—78000
on ------------ on ------------ Routing----39.68 —77500-----300.24----73300---------823.36—67800
on ------------ on ------------ Bridging----29.9 ----58400-----232.24----56700---------660.63—54400
But in practice, in normal use of http internet traffic, what is the throughput? What is the frame size?
I just need to know if the 450G can handle 2 Wan of 25Mb each (50Mb total), with IP Connection Firewall and conntrack in normal conditions (with a mangle, etc. optimized)
Thank you very much
