Hi all, I’m trying to help a non-profit organization who is replacing their router. The old router is kaput so I cannot glean anything from the old config. I have limited router knowledge and not specific to Mikrotik.
The problem is that Internet is not working. When I plug in the WAN port the router does say ‘reachable’ for the WAN IP but does not provide access (tested by trying to browse and by pinging 8.8.8.8, no go).
The network is simple, one LAN on 10.0.0.0/24 and one outgoing WAN connection. I will paste my config below but here’s the gist of it:
WAN is ether13
For the LAN I have bridged Ethernet ports 2 through 12 and configured DHCP for them.
Ether 1 I just left with the standard 192.168.88.1 as a way to be sure I can get in to the router in case I screw something up in IP settings.
I have also configured simple pcq queues so users can share bandwidth equally.
i suspect there’s something wrong with my routing table but have very little experience with that. My ISP said my WAN IP is 208.83.199.242 with subnet 255.255.255.252 and that my gateway to the Internet is 208.83.199.241. I have Masquerade configured as I believe that’s how to run a LAN network sharing one WAN IP.
That’s about it, super simple I should think but it’s not passing any Internet traffic, any help would be super appreciated so I can get these guys up and running again, they do good really good work and help a lot of people but don’t have much money to hire a professional.
Here’s the config:
may/27/2019 21:56:13 by RouterOS 6.42.7
software id = CKED-AUWZ
model = RB1100x4
serial number = 91D80AE30458
add fast-forward=no name=bridge1
set [ find default-name=ether13 ] name=ether13WAN
add name=dhcp_pool0 ranges=10.0.0.2-10.0.0.245
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
/queue type
set 5 pcq-rate=10M
set 6 pcq-rate=10M
/queue simple
add max-limit=12M/30M name=LimitAll queue=
pcq-upload-default/pcq-download-default target=10.0.0.0/24
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add address=192.168.88.1/24 comment=defconf interface=ether1 network=
192.168.88.0
add address=208.83.199.242 interface=ether13WAN network=208.83.199.252
add address=10.0.0.1/24 interface=bridge1 network=10.0.0.0
add address=10.0.0.0/24 dns-server=10.0.0.1,8.8.8.8 gateway=10.0.0.1
set allow-remote-requests=yes servers=8.8.8.8
add action=drop chain=input comment=“DROP SSH from WAN requests” dst-port=22
in-interface=ether13WAN protocol=tcp
add action=drop chain=input comment=“DROP webconfig from WAN requests”
dst-port=8081 in-interface=ether13WAN protocol=tcp
add action=drop chain=input comment=“DROP Winbox from WAN requests” dst-port=
8291 in-interface=ether13WAN protocol=tcp
add distance=1 gateway=208.83.199.241
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=0.0.0.0/0 port=8081
set ssh address=10.0.0.0/24
set api disabled=yes
set winbox address=0.0.0.0/0
set api-ssl disabled=yes
/system clock
set time-zone-name=US/Pacific
/system identity
set name=MikroTikLV
/system routerboard settings
set silent-boot=no
/tool graphing interface
add
