You really should provide export of config so we can check what else you did.
On a more serious note... what version of ROS ? What device used as capsman controller ?
BUT ... /ip wifi interface capsman ? I highly doubt it. That's a non-existing menu path as far as I know.
So once again, we really need to see that export
However, I THINK you are referring to GUI / Wifi and then button labeled Capsman.
In the dialog box there you can see interfaces to be used and generated (CA) certificates.
I don't think that will be enough , we also need a schematics of the network and the configurations of all devices involved, a list of users, their groups if any, and of course a description of the expected way the whole stuff should work.
Try to get some rest and get over the flu, instead of fiddling with RouterBOARDs...
/interface wifi capsman
set enabled=no
set !certificate
set !ca-certificate
set !interfaces
set !package-path
set !require-peer-certificate
set !upgrade-policy
Before anyone says, "Why don't you just do it on one line?", well, figure it out yourself instead of asking...
hahaha, I am getting over the flu, but had to go race in the last PAS Zwift race before they ended.
Wheezing at the moment but really enjoy you phuckers!
Sorry erlinden I have been avoiding the wifi forum, did you miss me??
I didnt expect the rest of you sorry lot to be hanging around in here though.
I obviously was typing from memory seeing the config ;-PP
