Simple,default configuration for PC/MAC through Wireguard to LAN
Hi All,
Havent yet created the schematics, however for a basic settings following description should be enough.
Mikrotik router set to 192.168.11.1 ( C53UiG+5HPaxD2HPaxD )
pool set 192.168.11.2-192.168.11.99
I would like to use my pc/mac to reach the home LAN network remotely.
What are the most default settings for mikrotik and wireguard client.
A. Current cfg enclosed,
# 2023-10-21 06:10:37 by RouterOS 7.11.2
# software id = YXRR-3U0P
# model = C53UiG+5HPaxD2HPaxD
# serial number = xy
add admin-mac=xy auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi2 ] channel.band=2ghz-ax .width=20mhz \
    configuration.mode=ap .ssid=xy2.4G datapath.bridge=bridge \
    disabled=no name=xy2.4G security.authentication-types=\
    wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=\
    xy5g disabled=no name=xy \
    security.authentication-types=wpa2-psk,wpa3-psk
add configuration.mode=ap .ssid=IOT mac-address=4A:A9:8A:09:8A:26 \
    master-interface=xy2.4G name=w_IOT
/interface wireguard
add comment=vpn_wg1 listen-port=13231 mtu=1420 name=wg1
add comment=defconf name=WAN
add comment=defconf name=LAN
/iot lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU \
    up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US \
    up-port=1700
add address=eu1.cloud.thethings.industries down-port=1700 name=\
    "TTS Cloud (eu1)" up-port=1700
add address=nam1.cloud.thethings.industries down-port=1700 name=\
    "TTS Cloud (nam1)" up-port=1700
add address=au1.cloud.thethings.industries down-port=1700 name=\
    "TTS Cloud (au1)" up-port=1700
add address=eu1.cloud.thethings.network down-port=1700 name="TTN V3 (eu1)" \
    up-port=1700
add address=nam1.cloud.thethings.network down-port=1700 name="TTN V3 (nam1)" \
    up-port=1700
add address=au1.cloud.thethings.network down-port=1700 name="TTN V3 (au1)" \
    up-port=1700
add name=dhcp ranges=192.168.11.10-192.168.11.99
add add-arp=yes address-pool=dhcp interface=bridge lease-time=10m name=\
    defconf
/interface bridge filter
# no interface
add action=drop chain=forward in-interface=*9
# no interface
add action=drop chain=forward out-interface=*9
# no interface
add action=drop chain=forward in-interface=*A
# no interface
add action=drop chain=forward out-interface=*A
add bridge=bridge comment=defconf interface=xy5g
add bridge=bridge comment=defconf interface=xy2.4G
add bridge=bridge interface=*9
add bridge=bridge interface=*A
add interface=wg1 list=LAN
/interface wireguard peers
add comment=xy interface=wg1 public-key=\
    "xy="
add address=192.168.11.1/24 comment=defconf interface=bridge network=\
    192.168.11.0
add address=192.168.22.1/24 interface=wg1 network=192.168.22.0
/ip arp
add address=192.168.11.100 interface=bridge mac-address=xy
add address=192.168.11.2 interface=bridge mac-address=xyxy
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.11.2 client-id=1:xyxy mac-address=\
    xyxy server=defconf
add address=192.168.11.100 mac-address=xy
add address=192.168.11.0/24 comment=defconf dns-server=192.168.11.1 gateway=\
    192.168.11.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.11.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat disabled=yes out-interface=wg1 \
    src-address=192.168.11.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Budapest
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
B. Client settings enclosed.
[quote][Interface]
PrivateKey = xy
Address = 192.168.11.101/24
[Peer]
PublicKey = xy
AllowedIPs = 0.0.0.0/0
Endpoint = xy:13231
[/quote]
Help is very appreaciated as I have spent 2-3 days tryng several settings without success.
If you follow the example, you will probably do just fine:
https://help.mikrotik.com/docs/display/ROS/WireGuard#WireGuard-RoadWarriorWireGuardtunnel
tried, did - no success.
Obviously im doing “something” wrong, cannot find yet.
dyndns - seems ok
port forward - questioned..
ip selections - questioned
You’re missing several key settings. You haven’t got the public key in the local peer config, you’re leaving DNS unset, and you haven’t got allowed IP assignments on the router side. There may be more I’m missing besides; I quit looking when I hit three. :man_facepalming:
EDIT: nope, four things missing: there’s no “accept” rule in the firewall for the WG port!
Try my tutorial, but without the double-NAT bit that you don’t need.
well, thank for hints, but as stated before, I have tried several howtos…
here lost again.
Partially seems ok, my routeros sitting as main router in my home: 192.168.11.1, with some.dyndns address.
Intention is to get connected from anywhere ( hotel, remote, mobile etc) and send all traffic through wireguard, and get acces to my home lan.
I do not mind getting random ports.
tried:
action=accept - how?
add allowed-address=192.168.77.2/32 interface=wg1 public-key="xy="
add address=192.168.77.1/24 interface=wg1
add action=src-nat chain=srcnat src-address=192.168.77.0/24 to-addresses=192.168.11.1
[Interface]
PrivateKey = xy/xy=
Address = 192.168.77.2/32
[Peer]
PublicKey = xy=
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = some.dyndns.pro:12345
Aside from reading the relevant docs, you could’ve gotten that from mducharme’s tutorial, linked from the top of mine:
/ip firewall filter add action=accept chain=input comment="Allow Wireguard" dst-port=12345 protocol=udp
Without this, your gateway router will drop all inbound WG packets from the Internet.
(My tutorial doesn’t include this because the port-forward from the gateway router takes care of that part of the problem, and my internal WG endpoint switch doesn’t have a firewall.)
add allowed-address=192.168.77.2/32 interface=wg1 public-key=“xy=”
Better.
<br>
> ```text
[Peer]
PublicKey = xy=
You don’t show a PresharedKey setting. It’s supposed to be optional, but if you applied it on the RouterOS side, you need it here, too.
I do appreciate the hints..
however the request been to get a simplified solution/example to setup a simple tunel settings for wireguard , LAN - remote access.
With all the hints, and days of tries i did not succeded, hence requested a simple example.
so far still something is wrong, if i could get a clue what, i whould have fixed that.
Bit of frustration as I though a simple tunel settings would be simpe…
help is appreciated, though.
routeros:
# 2023-10-23 09:53:04 by RouterOS 7.12rc2
    wpa2-psk,wpa3-psk
    xy disabled=no name=xy \
add configuration.mode=ap .ssid=dmsIOT mac-address=4A:A9:8A:09:8A:26 \
    master-interface=xy2.4G name=w_dmsIOT
add listen-port=12345 mtu=1420 name=wg1
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=\
    UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=\
    UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=\
    UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
    defconf
# no interface
# no interface
# no interface
# no interface
add allowed-address=192.168.77.2/32 client-listen-port=12345 interface=wg1 \
    private-key="xy=" public-key=\
    "xy="
    192.168.11.0
add address=192.168.77.1/24 interface=wg1 network=192.168.77.0
/ip arp
/ip dhcp-client
add address=192.168.11.2 client-id=xy mac-address=\
    F0:79:59:D2:AD:BC server=defconf
add address=192.168.11.200 client-id=xy mac-address=\
    xy server=defconf
/ip dns static
    invalid
add action=accept chain=input comment="Allow Wireguard" dst-port=12345 \
    protocol=udp
add action=src-nat chain=srcnat src-address=192.168.77.0/24 to-addresses=\
    192.168.11.1
/ip upnp
set enabled=yes
/ip upnp interfaces
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system note
/system package update
set channel=testing
/system scheduler
add comment=dyndns_update interval=6h name=dyndns_update on-event="xy" policy=reboot start-time=startup
/tool mac-server
Client:
[Interface]
PrivateKey = xy
[Peer]
PublicKey = xy
Endpoint = xy.dyndns:12345
You don’t want “simple,” you want me to write your configuration for you, and I simply am not going to do that. I expect you to interpose your brain between my “hints” and your local configuration, applying those hints intelligently. I don’t think it’s too much to ask that you do some of the thinking here. Am I wrong?
A quick scan of your posted configuration shows an obvious problem: you’ve put the new firewall “allow” rule after the “defconf: drop all not coming from LAN” rule, causing it to not apply. I didn’t think I needed to tell you that the order of firewall rules matters, and that you must to put the new rule above any relevant “drop” rules if you want it to have any useful effect.
https://forum.mikrotik.com/viewtopic.php?t=182340
well, literally yes, I would appreciate if someone could “write” the simple configuration - then I would be able to implement for my needs.
Morally this may disturb someone, but thats been the main querie " simple settings for remote access LAN".
Obvioulsy, If i would be able/could have figure out how to setup, I wouldnt rise the “simple setting” question.
So appreciate the help, but didnt have properly working solution, yet.
