I am following this Wiki exactly.
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
In an attempt to send my voip traffic down one connection (pppoe) and the LAN subnet (cable DHCP) through the other.
I am successfully marking the packets and have an active static gateway for the pppoe (eth5) and a dynamic gateway for the cable DHCP (eth1). I am trying to send the voip vlan out eth5 pppoe and the PC lan traffic out eth1 cable DHCP.
Pretty straight forward I believe but, no go for the phone route. Below is the NAT, Mangle, Routes and pppoe info if you can take a peak and shed some light.
Thanks in advance.
chain=srcnat action=masquerade to-addresses=0.0.0.0
src-address=192.168.88.0/24 out-interface=ether1-gateway log=no
log-prefix=""
1 chain=srcnat action=masquerade src-address=192.168.89.0/24
out-interface=pppoe-out1 log=no log-prefix=""
2 chain=prerouting action=mark-routing new-routing-mark=phones passthrough=n>
src-address=192.168.89.0/24 log=no log-prefix=""
3 X chain=prerouting action=mark-routing new-routing-mark=lan passthrough=no
src-address=192.168.88.0/24 log=no log-prefix=""
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 xx.xx.237.254 1
1 ADS 0.0.0.0/0 xx.xx.230.1 1
2 ADC xx.xx.237.254/32 xx.xx.237.25 pppoe-out1 0
3 ADC xx.xx.230.0/23 xx.xx.231.20 ether1-gateway 0
4 ADC 192.168.88.0/24 192.168.88.1 bridge-local 0
5 ADC 192.168.89.0/24 192.168.89.1 vlan100.bridge-... 0
0 R name="pppoe-out1" max-mtu=1480 max-mru=1480 mrru=1600
interface=ether5-slave-local user="weaer@here.net" password="123456"
profile=default keepalive-timeout=60 service-name="" ac-name=""
add-default-route=no dial-on-demand=no use-peer-dns=yes
allow=pap,chap,mschap1,mschap2
