hi! I have 2 ISP’s, one have 200mbps and the other have 50mbps. I use simple failover method with distance 1 for the 200mbps ISP and distance 2 for the 50mbps (backup). I use ISP1 for outgoing traffic and ISP2 only if ISP1 goes down. The problem is i want to have access to both WAN adresses from the outside. What is the simplest solution (without mangle). Thanks in advance!
hi
If you can isolate isp2 usage to some ip/range, then you could configure routing rule(s) to route traffic from these ips over ips2.
=> dedicated usage
otherwise it’s not possible without mangling
Can you point me to simple failover solution (without load balance) with mangle.
Tnx for fast reply
