hello,
(latest edition with working configurations for master and slave APs from Mikrotik)
situation:
there is 1 Gbps DHCP internet and 5 hAP ax² MT routers (routeros 7.21.2, wifi-qcom 7.21.2), I want setup CAPsMAN controlled wifi network
guest-wifi is working, but guest isolation is done by bridgeGuest ARP: ’reply-only’ and 2 routing rules
may be better isolation for guest wifi can be done via VLANs? (be happy with help from smart colleagues)
any comments be great!
(ap-master)
# model = C52iG-5HaxD2HaxD
add arp=reply-only name=bridgeGuest
add name=bridgeLAN port-cost-mode=short
set [ find default-name=ether1 ] mac-address=04:F4:1C:DE:79:5E
set [ find default-name=ether2 ] mac-address=04:F4:1C:DE:79:5F
set [ find default-name=ether3 ] mac-address=04:F4:1C:DE:79:60
set [ find default-name=ether4 ] mac-address=04:F4:1C:DE:79:61
set [ find default-name=ether5 ] mac-address=04:F4:1C:DE:79:62
add name=WAN
add name=LAN
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=2G
add band=5ghz-ax disabled=no name=5G skip-dfs-channels=10min-cac
/interface wifi datapath
add bridge=bridgeLAN disabled=no name=datapathLAN
add bridge=bridgeGuest client-isolation=yes disabled=no name=datapathGuest
/interface wifi security
add authentication-types=wpa3-psk disabled=no encryption=ccmp ft=yes \
ft-over-ds=yes group-encryption=ccmp group-key-update=20m name=Security
ft-over-ds=yes group-encryption=ccmp group-key-update=20m name=\
SecurityGuest
/interface wifi configuration
add channel=2G country=Latvia datapath=datapathLAN datapath.bridge=bridgeLAN \
disabled=no mode=ap name=2G security=Security ssid=KS
add channel=5G country=Latvia datapath=datapathLAN datapath.bridge=bridgeLAN \
disabled=no mode=ap name=5G security=Security ssid=KS
add channel=2G country=Latvia datapath=datapathGuest datapath.bridge=\
bridgeGuest disabled=no mode=ap name=2Gguest security=SecurityGuest ssid=\
KSguest
add channel=5G channel.band=5ghz-ax .skip-dfs-channels=10min-cac country=\
Latvia datapath=datapathGuest datapath.bridge=bridgeGuest disabled=no \
mode=ap name=5Gguest security=SecurityGuest ssid=KSguest
add name=dhcpLANPool ranges=192.168.88.2-192.168.88.254
add name=dhcpGuestPool ranges=192.168.188.2-192.168.188.254
add address-pool=dhcpLANPool interface=bridgeLAN name=dhcpLAN
add add-arp=yes address-pool=dhcpGuestPool interface=bridgeGuest name=\
dhcpGuest
add bridge=bridgeLAN interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridgeLAN interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridgeLAN interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridgeLAN interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridgeLAN interface=*2
add bridge=bridgeLAN interface=*3
add interface=ether1 list=WAN
add interface=bridgeLAN list=LAN
/interface wifi cap
set enabled=yes
/interface wifi capsman
set enabled=yes interfaces=all
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=5G \
name-format=5G-%I slave-configurations=5Gguest supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=2G \
name-format=2G-%I slave-configurations=2Gguest supported-bands=2ghz-ax
add address=192.168.88.1/24 interface=bridgeLAN network=192.168.88.0
add address=192.168.188.1/24 interface=bridgeGuest network=192.168.188.0
/ip dhcp-client
add address=192.168.88.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.88.1
add address=192.168.188.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.188.1
set servers=1.1.1.1,8.8.8.8
add action=fasttrack-connection chain=forward comment=\
"fast-track for established,related" connection-state=established,related
add action=accept chain=input connection-state=established
add action=accept chain=input comment="accept established,related,untracked" \
add action=accept chain=forward comment="accept established,related" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=drop chain=input in-interface-list=!LAN
"drop access to clients behind NAT from WAN" connection-nat-state=!dstnat \
connection-state=new in-interface=ether1
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set ssh port=2200
set winbox address=192.168.88.0/24
set api disabled=yes
/ip ssh
set strong-crypto=yes
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/routing rule
add action=unreachable disabled=no dst-address=192.168.188.0/24 src-address=\
192.168.88.0/24
add action=unreachable disabled=no dst-address=192.168.88.0/24 src-address=\
192.168.188.0/24
/system clock
set time-zone-name=Europe/Riga
/system identity
set name=MikroTik-cAP-m
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
(router-ap-slave)
add comment=defconf name=bridgeLocal
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# managed by CAPsMAN 04:F4:1C:DE:78:D2%bridgeLocal, traffic processing on CAP
# mode: AP, SSID: KS, channel: 5745/ax/Ceee
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
datapath=capdp disabled=no
# mode: AP, SSID: KS, channel: 2412/ax/Ce
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap \
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
/interface wifi cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/system clock
/system identity
set name=MikroTik-cAP-s4
