Device: hAP ac^2
RouterOS: 7.1.1
Subnet: 192.168.1.0/24
Router IP: 192.168.1.1
Server IP: 192.168.1.41
I am trying to configure a hairpin NAT for ports 22, 80, 443 to my server.
Port forwarding works fine if accessing by the domain name from the Internet, so ISP and the domain provider are not to blame.
I am monitoring all packages on the said ports on the server via TCPDump.
When trying to access the server by the domain name from my home network, THERE ARE NO INCOMING PACKAGES ON THE SERVER.
If I disable the masquerade rule, connections time out.
If I enable it, the clients will try to connect to ports 22, 80, and 443 of the Mikrotik router, not to those of the server.
How do I fix it?
Dump of my firewall config:
jan/05/1970 23:27:32 by RouterOS 7.1.1
software id = 4ZQL-60G6
model = RBD52G-5HacD2HnD
serial number = C6140C174DF0
add action=accept chain=input comment="defconf: accept SSH" dst-port=22
protocol=tcp src-address=0.0.0.0
add action=accept chain=forward comment="defconf: accept qBitTorrent TCP"
dst-port=12750 protocol=tcp src-address=0.0.0.0
add action=accept chain=forward comment="defconf: accept qBitTorrent UDP"
dst-port=12750 protocol=udp src-address=0.0.0.0
add action=accept chain=forward comment="defconf: accept HTTP" dst-port=80
add action=accept chain=forward comment="defconf: accept SSL" dst-port=443
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=netmap chain=dstnat dst-port=22 in-interface=ether1 protocol=tcp
to-addresses=192.168.1.41 to-ports=22
add action=netmap chain=dstnat dst-port=80 in-interface=ether1 protocol=tcp
to-addresses=192.168.1.41 to-ports=80
add action=netmap chain=dstnat dst-port=443 in-interface=ether1 protocol=tcp
to-addresses=192.168.1.41 to-ports=443
add action=src-nat chain=srcnat dst-address=192.168.1.41 dst-port=22
protocol=tcp src-address=192.168.1.0/24 to-addresses=192.168.1.1
add action=src-nat chain=srcnat dst-address=192.168.1.41 dst-port=80
add action=src-nat chain=srcnat dst-address=192.168.1.41 dst-port=443
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
P.S.: I absolutely need to access the server from within my home network by its domain name and not by its local IP. It runs an app that I use all the time which only works if you access it by HTTPS.
