I’m using MT with Radius manager, all of users do PPPoE connections and they get a public IP. I’m over limit with public IPs so NAT is the next solution in this moment until I get more IPs.
Is there a simple way to share one public IP to 2 or 4 hosts without big changing in setup of my MT. I think to run a masquerade on the public subnet and on some way start this options if it is possible.
As you are using your Mikrotik as Router for public IPs i dont think masquerade is the right option here. you need to use SRC-NAT. so to accomplish that just add one of the public IPs you have to your router WAN interface and use SRC-NAT for local IPs to SRC-NAT using this IP.
In case as you explain me, we have always one of local subnet through one fixed public IP. I know that I can break the local subnet in small subnets with small number of hosts, or I can make address lists and connect one address list to one public IP. All these are manual options.
I want to use some dynamically option and when number of customers spend all of public IP(first pool) then they will take the IPs from other smallest public pool (as a next pool) where they will share a one public per 4 local hosts. This option will come in only a short part of the day where I have all users active in the network so after that they will use again one local host per one public and the storm will calm.
1 Hotspot is the pool (DHCP enabled) from user come to make PPPoE connection, PPPoE server grant addresses from PPPoE_Public1. The next pool after “3” is “0” and there is small backup pool with public IPs that I ask for. That is all, I do not have any addition setup in firewall about this.
Please let me know if you need something more.
I would like to see your interfaces, ip address binding, and NAT rules if you have any.
How ever i will explain the general idea you can later modify it as you like.
In your scenario i am going to reserve 4 public IPs for the Router it self, these public ip are going to be used for NAT. i will take these IPs from your “PPPoE_Public1” scope and then i will cerate a new scope called “PPPoE_Private” this scope has 31 private IPs.
1- reserving 4 public ips:
add address=1.1.1.251/24 int=[put your wan interface]
add address=1.1.1.252/24 int=[put your wan interface]
add address=1.1.1.253/24 int=[put your wan interface]
add address=1.1.1.254/24 int=[put your wan interface]
