Simple NAT rule
I want to create simple NAT rule to forward FTP (21) port to my LAN server (192.168.88.10).
I create this way:
/ip firewall nat add action=dst-nat chain=dstnat disabled=no dst-port=21 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.88.10 to-ports=21
But in the web interface I got this:
There is nothing about the server IP, is there something wrong?
Kind regards.
If you click on the rule, you can see the full list. It will include the to-address.
Thanks, but I want to do it with command-line.
Then configure some scripts.
Regards.
Set it up in Winbox and then open terminal end do EXPORT command.
You will see your configuration as commands so you can see how to do it in CLI.
Check your columns. the image shows src address and dst address, but your script is using in-interface and to-address. If you don’t have those columns turned on, you won’t see them.
Thanks!
One question, which “action” must I use to do a simple NAT from wan interface to LAN server?
Regards.
I got it!
/ip firewall nat add action=dst-nat chain=dstnat dst-address=10.X.X.X dst-port=21 in-interface=ether1-gateway protocol=tcp to-addresses=192.168.88.10 to-ports=21
But I have a problem, my WAN interface is a dynamic public one, is it possible to put a alias for it?
Best regards.
IP > Cloud
Thanks!
I enable the Cloud service, now I have a public domain.
So need I to use the “xxxxxxxxxxxx.sn.mynetname.net” in the “dst-address” configuration?
Best regards.
No, just use wan as in-interface
Thanks! It works for me.
Best regards.
