I have a 5 port Mikrotik router running router OS 5.4.
Have Ethernet1 connected to 192.168.0.0/24 network. Assigned the interface 192.168.0.1/24 all devices on this network have their default gateways configured for 192.168.0.1
Have Ethernet2 assigned 192.168.101.230/24, directly connected to 192.168.101.1, the switch 192.168.101.1 is connected to the 192.168.101.0/24 network.
When I navigate to IP/Routes, I have two DAC routes one for the 192.168.101.0/24 network says reachable, and the other DAC route is for the 192.168.0.0/24 network. These were dynamically discovered.
WHY? Please answer WHY? can I ping from any device on the 192.168.0.0/24 network to any device on the 192.168.101.0/24 network.
BUT I Cannot ping from the 192.168.101.0 network to anything on the 192.168.0.0/24 network.
I have tried adding default route 0.0.0.0/0 for Ethernet1, no go!!
The I added a default route 0.0.0.0/0 for Ethernet2, no go!!
Added default routes for both Ethernet1 & 2 at the same time, no go!!
Added various other routes attempting to pass a ping from the 192.168.101.0/24 network to the 192.168.0.0/24 network.
Nothing seems to allow a ping to pass in both directions on this device, only in one direction.
Does anyone have any suggestions? This is frustrating with something so simple.
Also, this is a basic routing config, I do not want firewall rules, NAT rules, filters or anything else, just a simple division of two networks so broadcast packets will not be forwarded, but devices can be accessed from each network across the router.
Thanks for any help in advance!
