Simple policy routing question
We have two WAN connections. One is used as primary internet and one has a lower priority route that’s used as a backup internet connection (not load balanced).
We’d like the ability to send traffic from certain LAN IPs through the backup internet connection at all times, even when the primary internet is still online.
I found https://wiki.mikrotik.com/wiki/Policy_Base_Routing and am trying to adapt this for our setup (i.e., the same process but without a VPN connection).
Here are the relevant rules:
/ip firewall address-list add address=<LAN_IP> comment=laptop-enet list=BACKUP_INTERNET
/ip firewall mangle add action=mark-routing chain=prerouting new-routing-mark=BACKUP_INTERNET passthrough=no src-address-list=BACKUP_INTERNET
/ip route add distance=1 gateway=<BACKUP_INTERNET_GATEWAY_IP> routing-mark=BACKUP_INTERNET
/ip route add distance=1 gateway=<PRIMARY_INTERNET_GATEWAY_IP>
/ip route add distance=10 gateway=<BACKUP_INTERNET_GATEWAY_IP>
This works fine for some things, but certain HTTPS connections get terminated almost immediately. It is very domain-specific, i.e., a URL will always succeed or always fail. This appears as a “connection reset” message in the browser, and looks like this in curl (github.githubassets.com always fails):
$ curl -v -I https://github.githubassets.com/assets/frameworks-a2fba223d5af91496cac70d4ec3624df.css
  • Trying 185.199.109.154…
  • TCP_NODELAY set
  • Connected to github.githubassets.com (185.199.109.154) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
  • successfully set certificate verify locations:
  • CAfile: /etc/ssl/cert.pem
    CApath: none
  • TLSv1.2 (OUT), TLS handshake, Client hello (1):
  • LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.githubassets.com:443
  • stopped the pause stream!
  • Closing connection 0
    curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.githubassets.com:443
    Yet with the same firewall configuration, github.com works fine:
    $ curl -v -I https://github.com/
  • Trying 192.30.253.113…
  • TCP_NODELAY set
  • Connected to github.com (192.30.253.113) port 443 (#0)
  • ALPN, offering h2
    CApath: none
  • TLSv1.2 (IN), TLS handshake, Server hello (2):
  • TLSv1.2 (IN), TLS handshake, Certificate (11):
  • TLSv1.2 (IN), TLS handshake, Server key exchange (12):
  • TLSv1.2 (IN), TLS handshake, Server finished (14):
  • TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
  • TLSv1.2 (OUT), TLS change cipher, Client hello (1):
  • TLSv1.2 (OUT), TLS handshake, Finished (20):
  • TLSv1.2 (IN), TLS change cipher, Client hello (1):
  • TLSv1.2 (IN), TLS handshake, Finished (20):
  • SSL connection using TLSv1.2 / ECDHE-RSA-CHACHA20-POLY1305
  • ALPN, server accepted to use http/1.1
  • Server certificate:
  • subject: businessCategory=Private Organization; jurisdictionCountryName=US; jurisdictionStateOrProvinceName=Delaware; serialNumber=5157550; C=US; ST=California; L=San Francisco; O=GitHub, Inc.; CN=github.com
  • start date: May 8 00:00:00 2018 GMT
  • expire date: Jun 3 12:00:00 2020 GMT
  • subjectAltName: host “github.com” matched cert’s “github.com
  • issuer: C=US; O=DigiCert Inc; OU=www.digicert.com; CN=DigiCert SHA2 Extended Validation Server CA
  • SSL certificate verify ok.
HEAD / HTTP/1.1
Host: github.com
User-Agent: curl/7.54.0
Accept: /
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
From the primary internet connection (or when the entire office has been moved over to the backup internet connection), it github.githubassets.com works fine, too
  • TCP_NODELAY set
  • ALPN, offering h2
    CApath: none
  • SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
  • ALPN, server accepted to use h2
  • subject: C=US; ST=California; L=San Francisco; O=GitHub, Inc.; CN=*.githubassets.com
  • start date: Oct 29 00:00:00 2018 GMT
  • expire date: Nov 2 12:00:00 2020 GMT
  • subjectAltName: host “github.githubassets.com” matched cert’s “*.githubassets.com”
  • issuer: C=US; O=DigiCert Inc; OU=www.digicert.com; CN=DigiCert SHA2 High Assurance Server CA
  • Using HTTP2, server supports multi-use
  • Connection state changed (HTTP/2 confirmed)
  • Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
  • Using Stream ID: 1 (easy handle 0x7f8d4b808a00)
HEAD /assets/frameworks-a2fba223d5af91496cac70d4ec3624df.css HTTP/2
Host: github.githubassets.com
Accept: /
  • Connection state changed (MAX_CONCURRENT_STREAMS updated)!
    < HTTP/2 200
    HTTP/2 200
    What could be causing this and/or what is the “correct” way to accomplish what we are trying to do?
Thank you in advance!
I would first disable all the policy routing and set for a while the backup route as primary (or shut down the primary’s WAN interface, whatever) to see whether the issue persists or not. If it does, it is most likely some MTU issue on the secondary WAN’s route; if it doesn’t, there is an issue in the policy routing.
Hello and thanks very much for the reply!
When failing over to the backup internet the normal way (not using a routing mark), the issue does not exist. Also, the two routes are identical except for the distance and routing-mark parameters (I have not simplified the rules for the purposes of this post):
In that case, publish the complete configuration, following the hints regarding anonymisation in my automatic signature.
