Does Mikrotik support PHP (hotspot).
Thanks.
Thanks.
On the router itself? No.
–Tom
Just HTML & Javascript?
txs
umm, no! you can’t put your own webpages on the router
I see, but… inside mikrotik i cannot make php pages, just javascript & html.
Is it?
txs
no, inside mikrotik you cannot store any html,xhtml,php,java,javascript,css,txt or any other files that you want to be displayed on it’s webpage.
please explain what would like to do, so that i can give a better answer.
RouterOS is not a webserver of any kind.
oh, sorry, I mean:
Inside hotspot files.
When I try to customize.
txs
normis:
no, inside mikrotik you cannot store any html,xhtml,php,java,javascript,css,txt or any other files that you want to be displayed on it's webpage.
oh, sorry, I mean:
txs
yes, i think you can customizing hotspot page as you want...
i did do it... ![]()
inside hotspot login pages you can only use html and javasctipt. basically you are limited to just editing the provided files.
ooookay txs!!!
Can you helpme with this post?
http://forum.mikrotik.com/t/trying-to-understand-destination-nat/11392/1
I’m little bit desperate… ![]()
txs.
you can whatever you want with the login page .. just leave the username and password fields as it is or in another place and you can add anything you want.
very many thanks.
