hi…all
how can i up grade mt..?
i used 2.9.7 now i want to upgrade to 2.9.10, can anybody tell me in the easy way…how to upgrade it..?
thx
- download it from the Mikrotik web site
- open an ftp session to the router (I use Internet Explorer for this)
- copy the file across
- reboot the router
- cross your fingers!
even easier
login with winbox, open files window and drag the *.npk file into the window and reboot
I should have known it could be that easy
After the reboot, check and if required re-enter your firewall rules.
Regards
Andrew
