I have an issue with simple queues “interface” which I have set the customer PPPoE number (Say User_150) but when the client disconnects it get I (invalid) with this entry goes red and reverts to “all” interfaces but does not continue the traffic counter when the customer connects again to AP and even though I have a static pppoe IP address set on the CPE, I have to reselect pppoe number again (user_150),
Can I request help with script and advice on how to address this issue, please.
Add static entry in /interface pppoe-server menu then interface will not disappear.
Thank you MRZ but as usual i am a little confused here is some details on my configuration
#If I edit interface it will be =<pppoe-User_1124>
[admin@AP} > interface
[admin@AP] /interface> print
# NAME TYPE MTU L2MTU MAX-L2MTU
0 R ether1 ether 1500 1526 1526
1 ether2 ether 1500 1522 1522
2 R ether3 ether 1500 1522 1522
3 R wlan1 wlan 1500 2290
4 DR <pppoe-User_1123> pppoe-in 1480
5 DR <pppoe-User_1118> pppoe-in 1480
6 DR <pppoe-User_1066> pppoe-in 1480
7 DR <pppoe-User_1103> pppoe-in 1480
8 DR <pppoe-User_1104> pppoe-in 1480
9 DR <pppoe-User_1101> pppoe-in 1480
10 DR <pppoe-User_1106> pppoe-in 1480
11 DR <pppoe-User_1129> pppoe-in 1480
12 DR <pppoe-User_1124> pppoe-in 1480
13 DR <pppoe-User_1114> pppoe-in 1480
/interface pppoe-server server
add authentication=mschap2 default-profile=default-encryption disabled=no \
interface=wlan1 keepalive-timeout=10 max-mru=1480 max-mtu=1480 \
max-sessions=0 mrru=disabled one-session-per-host=no service-name=\
service1
/ppp secret
add caller-id="" disabled=no limit-bytes-in=0 limit-bytes-out=0 name=\
User_1124 password=XXXXXXXX profile=Standard_Package remote-address=\
10.150.7.248 routes="" service=pppoe
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="John Doe" \
direction=both disabled=no interface=all limit-at=0/0 max-limit=128k/1M \
name=User_1124 parent=none priority=8 queue=default/default \
target-addresses=10.150.7.248/32 total-queue=default
add name=User_1111 user=“User_1111” service=“”
/queue simple
add interface=“User_1111” name=user-1111-queue …
Thank you, still had problems until i removed remote address from pppoe-pool, all Ok Now
From
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=default use-encryption=default use-mpls=default use-vj-compression=default
add change-tcp-mss=yes local-address=10.150.7.1 name=Standard_Package only-one=default rate-limit=384k/3M remote-address=pppoe-pool use-compression=default use-encryption=default use-mpls=default use-vj-compression=default
To
/ppp profile
add change-tcp-mss=yes local-address=10.150.7.1 name=Profile3M only-one=default rate-limit=384k/3M use-compression=default use-encryption=default use-mpls=default use-vj-compression=default
I discovered an issue with using
In simple queues two entries are now listed for each customer
(1) Static address (10.150.1.200/32 ) from pppoe-server interface
(2) Dynamic (10.150.1.200/32) from pppoe-client /ppp secret
This has caused what appears to be dual traffic shaping process for these entries ?
