Simple queue and transfer limitation
Hello.
I have main CAKE simple queue like:
/queue simple
add max-limit=275M/135M name=wan-queue-cake queue=cake-wan-rx/cake-wan-tx target=ether1
where ether1 is WAN port and it works perfectly.
Then I want to add limitation to single IP (lets call them IP#A), for example download 50Mbit from ISP to IP#A and upload 10Mbit from IP#A to ISP. After some digging I expected this solution will work:
/queue simple
add max-limit=10M/50M name=qPS5Wv1 parent=wan-queue-cake queue=ethernet-default/ethernet-default target=IP#A
but unfortunatelly not - it does not works, instead of them this:
/queue simple
add dst=IP#A max-limit=50M/10M name=qPS5Wv2 parent=wan-queue-cake queue=ethernet-default/ethernet-default target=ether1
works (download from ISP to IP#A, I does not have possibility to verify upload from IP#A to ISP).
And the question is: why first variant does not work?
