Hi to all, i really don’t know if this is the right place to post this, please correct me if it is not… i would like to report a problem that i found with last version 6.37.3.
The problem is that when i have simple queues, there is not a real bandwith control. When i see for example 20Mbps of download rate in the PPPoE interface, at the simple queue the parent queue says that are 300Kb of download rate. This problem fixes when i run a Torch on the LAN interface. While Torch is running, queue works fine… When torch stops, queue have mistakes.
This problem i have with a lot of Hex and Hex-Lite with 6.37.3 firmware.
This same config on a 6.37 firmware on X86 works fine. and is the same config that i have been using for years, always working fine.
I already made a video, so you can see the problem, and a supout.rif file if you need it.
https://www.youtube.com/watch?v=SZDr4zIqynI
(i can’t attatch the supout.rif file to this post…)
Thanks in advance. Kind regards
