I have been using MT 2.9 as a hotspot server and have already created simple queue to max bandwidth limit for local traffic but when I try to limit other traffic sent by radius ‘Ascend-Data-Rate’ it comes at first of the queue as Dynamic queue. Why this is happening in only hotspot, but when I have tried same process in pppoe profile, the dynamic queue comes below.
Correct. PPP dynamic queue is created after list of static ‘queue simple’ entries.
It is not recommended to use ‘queue simple’ entries that may match the same traffic as order is important for ‘queue simple’ entries.
I am little bit confuse, please look into my scenario
I am using radius for accounting, authentication and individual bandwidth restriction as user base sent by radius as Ascend-Data-Rate but I want to limit max bandwidth for my local traffic.
Lets say, if dst-address is 192.168.100.x to limit bandwidth 1Mb and the radius sent BW restriction also should work for that traffic, which doesn’t match already, define queue.
I did it on pppoe using simple queue and have no problem but hotspot giving me problem.
Can you suggest me?
Yes, it works as it should.
HotSpot queues are created above static queues, you can use script each 1min or 5mint etc. that places static queues above other.
