Having a very odd time figuring out why queue priority doesn’t seem to be working for me.
Test setup: Symmetric 1000/1000 connection, Hex S, Router OS 6.46.1
Two internal dhcp scopes 192.168.88.1/24 (lan) and 192.168.68.1/23 (guest)
Test results from running speedtest on both at the same time is a 50/50 split of available bandwidth (one device on 192.168.88.252 showing ~ 450 meg download/upload, one device on 192.168.68.2 showing ~ 500 meg download/upload) versus what I’d expect is the priority to give 100M to guest queue and remaining 900M to LAN queue as it has a higher priority.
I’m pretty sure I’m not doing anything stupid, fastrack isn’t enabled. Verified devices IPs/etc.
Any ideas?
Tim
/queue simple
add max-limit=950M/950M name=Master queue=default/default total-queue=default
add limit-at=100M/100M max-limit=900M/900M name=lan parent=Master priority=6/6 queue=default/default target=192.168.88.0/24 total-queue=default
add limit-at=100M/100M max-limit=900M/900M name=guest parent=Master priority=7/7 queue=default/default target=192.168.68.0/23 total-queue=default
add action=accept chain=input comment=restr-mgnt-in src-address-list=restr-mgnt
add action=accept chain=forward comment=vlan200-in dst-address=10.0.1.216/29 src-address=0.0.0.0/0
add action=accept chain=forward comment=vlan200-out dst-address=0.0.0.0/0 src-address=10.0.1.216/29
add action=drop chain=forward comment=“drop traffic from guestlan-vlan600 to anything but ether1” in-interface=vlan600 out-interface-list=!WAN
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=set-priority chain=postrouting comment=“set 802.1p to 5 for voip packets” new-priority=5 packet-mark=voip passthrough=yes
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
