Simple queue not working in mikrotik V.6.15
Hi all,
i try to do simple queue as below script in Mikrotik v.6.15 but it’s not working at all.
script :
:for i from=2 to=256 do={/queue simple add target-address=(192.168.168.1.$i) max-limit=1M/1M burst-limit=900k/900k }
please help!!!
Thanks!
Karona Norm ( Mr. )
I’m assuming you wanted the target-address to change, not the net mask on it. Also, you can’t use the ‘M’ and ‘k’. Finally, you cannot have a burst-limit less than the max-limit. Burst-limit should be larger than max-limit and you would also need a burst-time and burst-threshold. For example:
   /queue simple add target-address=("192.168.168.".$i) max-limit=1000000/1000000 \
      burst-limit=5000000/5000000 burst-threshold=900000/900000 burst-time=180/180
However, I’d suggest you also research the PCC queue type to see if it might be more appropriate for what you might be trying to accomplish.
Thanks Bro, but anyway when i run your script it’s still not working. so what can i do?
This should work, since V6.x “target-address=” types as “target=”
:for i from=2 to=254 do={
/queue simple add target=(“192.168.168.”. $i . “/32”) max-limit=1000000/1000000 burst-limit=5000000/5000000 burst-threshold=900000/900000 burst-time=180/180;
yeah i think so but i try many time it’s not working as i expected..
please help…
Can you specify what exactly is not working?
when i run script it’s not working in simple queue, as before when i run kind of this queue script than simple queue will appear queue list. but now it’s nothing when i click ont run script.
This example:
/system script add name=queues source={
/system script run queues
Will add new 253 queues with target address from 192.168.168.2-192.168.168.254
You can also add one rule for whole subnet:
/queue simple
add burst-limit=5M/5M burst-threshold=900k/900k burst-time=3m/3m max-limit=1M/1M target=192.168.168.0/24
You configure Bridge/Vlan at ur interface ??
Then please check this one …
See the pic …
hope your problem will be solved
