I have about 320 simple queue and 22 vlans
for some reason the simple queue stop working in one way, so right now my customer can donaload all they want and is killing my intenrnet access
I need some help to solve this problems, thank you.
here is some the simple queue
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment=“”
direction=both disabled=yes dst-address=0.0.0.0/0 interface=all limit-at=
64k/64k max-limit=64k/64k name=“Limiting p2p” p2p=all-p2p parent=none
priority=8 queue=pcq/pcq target-addresses=10.0.0.0/8 total-queue=
default-small
direction=both disabled=yes dst-address=190.14.192.131/32 interface=all
limit-at=2M/2M max-limit=2M/2M name=voip-server-clarocom-1 parent=none
priority=1 queue=default-small/default-small target-addresses=10.0.0.0/8
total-queue=default-small
direction=both disabled=yes dst-address=190.14.192.132/32 interface=all
limit-at=2M/2M max-limit=2M/2M name=voip-server-clarocom-2 parent=none
direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=
0/0 max-limit=1k/1k name=“Vlan172 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.42.12.0/28 total-queue=
default-small
0/0 max-limit=10M/10M name=“Vlan174 Default” parent=none priority=8
queue=default-small/default-small target-addresses=10.42.16.0/28
0/0 max-limit=1k/1k name=“Vlan130 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.30.4.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan132 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.30.12.0/28 total-queue=
default-small
0/0 max-limit=0/0 name=“Vlan170 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.42.4.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan180 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.44.4.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan182 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.44.12.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan100 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.11.6.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan102 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.11.14.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan104 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.11.20.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan106 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.11.28.0/28 total-queue=
default-small
0/0 max-limit=1k/1k name=“Vlan108 Default” parent=none priority=8 queue=
default-small/default-small target-addresses=10.11.36.0/28 total-queue=
default-small
0/0 max-limit=2M/4M name=“Vlan190 Paitilla” parent=none priority=8 queue=
default-small/default-small target-addresses=10.45.0.0/24 total-queue=
default-small
QUEUE TREE (QoS)
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0
max-limit=0 name=imap-rx packet-mark=imap-rx parent=“UPLOAD Global-IN”
priority=2 queue=“PCQ UP”
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=yes limit-at=0
max-limit=0 name=Email_Out packet-mark=smtp-tx parent=global-out
max-limit=0 name=voip-sip-total packet-mark=voip-sip-total parent=
Global_Total- priority=1 queue=pcq
max-limit=0 name=voip-rtp-total packet-mark=voip-rtp-total parent=
max-limit=0 name=icmp-total packet-mark=icmp-total parent=
“DOWNLOAD - Global-OUT” priority=1 queue=“PCQ DOWN”
max-limit=0 name=http-total packet-mark=http-total parent=
“DOWNLOAD - Global-OUT” priority=4 queue=“PCQ DOWN”
max-limit=0 name=https-total packet-mark=https-total parent=Global_Total-
priority=4 queue=pcq
max-limit=0 name=Terminal_Service packet-mark=terminal-services parent=
Global_Total- priority=2 queue=pcq
max-limit=0 name=Magic-jack packet-mark=magicjack parent=
max-limit=3096k name=“Alberto Down - Dell” packet-mark=
“Alberto - Dell Down” parent=“vlan174 Voip Office” priority=8 queue=pcq
max-limit=1M name=“Alberto UP - Dell” packet-mark=“Alberto - Dell UP”
parent=“UPLOAD Global-IN” priority=8 queue=“PCQ UP”
max-limit=0 name=SMTP packet-mark=SMTP-25 parent=“UPLOAD Global-IN”
priority=3 queue=“PCQ UP”
max-limit=0 name=POP3 packet-mark=POP3-110 parent=“DOWNLOAD - Global-OUT”
priority=5 queue=“PCQ DOWN”
max-limit=0 name=icmp-up packet-mark=icmp-total parent=“UPLOAD Global-IN”
priority=1 queue=“PCQ UP”
/ip firewall mangle
add action=mark-packet chain=forward comment=“VOIP Office” disabled=yes
new-packet-mark=VOIP passthrough=no src-address=192.14.202.3
dst-address=190.14.202.3 new-packet-mark=VOIP passthrough=no
add action=mark-connection chain=forward comment=“” disabled=yes
new-connection-mark=p2p_conn p2p=all-p2p passthrough=yes
add action=mark-packet chain=forward comment=“” connection-mark=p2p_conn
disabled=yes new-packet-mark=p2p passthrough=yes
add action=mark-packet chain=forward comment=http-total disabled=no
new-packet-mark=http-total passthrough=yes port=80 protocol=tcp
add action=mark-packet chain=forward comment=“Voip sip total” disabled=no
dscp=26 new-packet-mark=voip-sip-total passthrough=yes
add action=mark-packet chain=prerouting comment=“HTTPS Total” disabled=no
new-packet-mark=https-total passthrough=yes port=443 protocol=tcp
add action=mark-packet chain=forward comment=“ICMP Total” disabled=no
new-packet-mark=icmp-total passthrough=yes protocol=icmp
add action=mark-packet chain=forward comment=“VOIP RTP Total” disabled=no
dscp=46 new-packet-mark=voip-rtp-total passthrough=yes
add action=mark-packet chain=forward comment=“Email Out” disabled=no
dst-port=25 new-packet-mark=SMTP-25 passthrough=yes protocol=tcp
src-port=25
add action=mark-packet chain=postrouting comment=“POP3 Email In” disabled=no
new-packet-mark=POP3-110 passthrough=yes protocol=tcp src-port=110
add action=mark-packet chain=prerouting comment=“IMAP TCP Email In” disabled=
no new-packet-mark=imap-rx passthrough=yes protocol=tcp src-port=143
add action=mark-packet chain=prerouting comment=“IMAP UDP Email In” disabled=
no new-packet-mark=imap-rx passthrough=yes protocol=udp src-port=143
add action=mark-packet chain=prerouting comment=“IMAP SSL Email In”
disabled=no new-packet-mark=imap-rx passthrough=yes protocol=tcp
src-port=993
add action=mark-packet chain=forward comment=“POP3 Port 995 SSL” disabled=no
new-packet-mark=POP3-995 passthrough=yes protocol=tcp src-port=995
add action=mark-packet chain=prerouting comment=“Email TLS/SSL Out” disabled=
no dst-port=465 new-packet-mark=smtp-tx passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting comment=“Terminal Services” disabled=
no dst-port=3389 new-packet-mark=terminal-services passthrough=yes
protocol=tcp
add action=mark-packet chain=prerouting comment=P2P disabled=no
new-packet-mark=p2p p2p=all-p2p passthrough=yes
add action=mark-packet chain=forward comment=Magicjack disabled=no dst-port=
5060-5070 new-packet-mark=magicjack passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=“Alberto Laptop Test”
disabled=no new-packet-mark=“Alberto - Dell UP” passthrough=yes
src-address=10.42.16.2
add action=mark-packet chain=postrouting comment=“” disabled=no dst-address=
10.42.16.2 new-packet-mark=“Alberto - Dell Down” passthrough=yes
add action=mark-packet chain=forward comment=“SMTP - 587” disabled=no
dst-port=587 new-packet-mark=“SMTP - Port 587” passthrough=yes protocol=
tcp src-port=587
