litu
1
Dear All,
I have found a problem in Mikrotik Router OS (example version is 4.6 for intel x86) which
is:
If I disable “Use IP Firewall” in bridge settings, all simple queues for bridge are not working and not limiting traffic ! But PPPoE USers are ok.
If I Enable “Use IP Firewall” in Bridge settings, all PPPoE users traffic not limiting but Bridge users are working just fine.
My question is: How can I traffic for both PPPoE & Bridge users in mikrotik ??
I saw in RB450, its just working fine ! Here (in RB450) in Bridge settings all are checked ! I mean enabled !
Please tell me what to do ??
Any suggestion ??
Regards.
and what about ‘Use IP Firewall for PPPoE’? =)
litu
3
Let me check with this and I will get back to you !
Ihave a customer with isues with simple queues+ros4.x+x86. Queues ar not limiting speed of users.
litu
5
this problem happen when bridge, pppoe services are running on the same box, i.e x86 machine. I had 3 interface. 1-wan, 1-lan-pppoe-server, 1-bridge.
If I fix the traffic limiting issue with pppoe users, bridge interface can not control/limit traffic and
if bridge interface is fixed to control traffic, in that case pppoe users queues are not limiting.
I saw in the forum that its depends on bridge>seettings where I can select
use IP firewall
use IP firewall for pppoe users
use IP firewall for VLAN
this control the activities related to traffic shaping. But I failed to fix it.
Do you have such case ??
Regards
I found disabling fast-path was the solution to get simple queues working:
/ip settings set allow-fast-path=no
