Simple queue problem in CCR-12g
Hi all,
actually I need to monitor BW graph based on queue. But I am facing difficulties to implement queue in router. This router has point to point connection with connectivity provider and several public ip blocks assigned in eth4 interface. I have assigned all ips to my different servers and they are so well. Now problem is I have several streaming server and they use huge BW and I need to monitor the same. I am creating queue based on target interface and destination address. The problem is there is only one queue runs at a time. If I disable one queue it starts showing usage in next queue. until then it shows 0k/0k. I tried to by using parent queue and the problem is same under parent.
Please suggest me what step should I take to make this queue usable.
Thanks in advance.
Can you post the output of “/queue simple print”, and a screenshot of Torch showing traffic to the different destination addresses you’re trying to match?
Hi DLNoah,
Please find below queue print for my router
[admin@Mikrotik] > /queue simple print
0 name=“Main” target=ether4 parent=none packet-marks=“” priority=8/8
queue=default-small/default-small limit-at=1024M/1024M
max-limit=1024M/1024M burst-limit=0/0 burst-threshold=0/0
burst-time=0s/0s
1 name=“AA” target=ether4 parent=Main packet-marks=“” priority=8/8
queue=default-small/default-small limit-at=0/0 max-limit=500M/500M
burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
2 name=“BB” target=ether4 parent=Main packet-marks=“” priority=8/8
queue=default-small/default-small limit-at=700M/700M max-limit=700M/700M
3 name=“A1” target=ether4 dst=103.242.20.0/22 parent=Robi
packet-marks=“” priority=8/8 queue=default-small/default-small
limit-at=300M/300M max-limit=300M/300M burst-limit=0/0
4 name=“B1” target=ether4 dst=202.4.173.0/24 parent=Teletalk
limit-at=500M/500M max-limit=500M/500M burst-limit=0/0
5 name=“B2” target=ether4 dst=103.230.104.0/22 parent=Teletalk
6 name=“A2” target=ether4 dst=202.134.8.0/21 parent=Robi
and I having traffic in all the queues in torch.
These two queues are both set up to match exactly the same thing, so only the first active one in line will ever match the traffic
I’m assuming that parent=Robi refers to queue AA and parent=Teletalk refers to queue BB, so these queues should be splitting traffic as you expect.
If you can add a packet-mark or change your target to distinguish traffic for AA and BB, you should get the results you expect for the other sub-queues.
