Simple queue problem
I have WAN port on Ether 1. It has VLAN port related to it. That VLAN is bridged to Ether 3. How can ensure commited information rate for that VLAN on ether 1? I try to put simple queue with target VLAN, but simple queue is not hitted by the rule.
Do i need bridge firewall to mark packets? So in which chain they should be marked?
It is IP television system, that is connected to Ether 3. Internal network is behind NAT. So i need to ensure some Mbs rate for TV.
You need to Queue the other traffic to reserve the bandwidth for IPTV.
Ether 3 is connected to set top box. So queuing will be done on ether 1 as i understand.
And that ether 1 is not a bridge port.
Do you have ideas of simple queue if target is multicast address?
