Still working on learning queues, but curious what the easiest way to do something is…
Suppose I have all of my computers in a subnet 192.168.0.0/24 and a server at 192.168.0.2/24. My connection is 20Mbps/2Mbps. I’d like to allow usage of the full bandwidth by all computers, but make sure that there is at least 5Mbps/1Mbps available if/when the server wants it. What is the easiest way to do that? Thanks.
At the moment, you’re probably best off with PCQ and Queue Tree.
Create a PCQ for your server to reserve the bandwidth, then create a separate PCQ for your workstations.
In the Queue Tree, create 2 parent queues (upload & download), then create 2 children for each (server & workstation).
What will happen, is that your server will always have bandwidth available and be able to use the full pipe when possible. Your workstations will equally share all bandwidth, up to the maximum of the pipe.
To ensure that this works as well as possible, I would suggest setting the parent queue bandwidth to about 95% of the actual available bandwidth (19m/1900k), and set your limit-at to about 75% of (15M/1500k).
