simple queue time scheduling problem
hey guys
thanks first for having a look.
i’m having an odd problem. i have a client and he needs an extra 5mb bandwidth at night from 8 pm to 8 am. during the day he uses 15mb.
i created three simple queue, the first with the time and the second without.
the problem is, when i add 20:00:00 to 00:00:00 it allows me to add it but remains RED in queue.
i added a second queue with 00:00:01 to 08:00:00, but the same problem exists, it remains RED in queue.
i can’t seem to be able to make this work however i try. does the red mean inactive and it activates at the time specified?
i’d appreciate help on this.
red is for equal to “not active at the moment”,
blue is for “overlapped”
black is for “working”
grey is for “disabled”
one hint: use
20:00:00 → 23:59:59
and
00:00:00 → 07:59:59
and
08:00:00 → 19:59:59
thank you rextended
i’ll give that a go
but why a time on the third one? if you would kindly elaborate.
Is better two/three not overlapped queue
thank you
if i now have a question regarding dhcp and mikrotik, would you be able to help?
if you not find solution after using search function on forum, open new topic and ask…
