niamul
October 6, 2009, 10:07am
1
hello
i have a mikrotik server 3.2
i have about 10 clients. some are corporate clients and some are distributors themselves.
what i want to do is limit bandwidth for the corporate clients after a certain time.
lets say i want to give them 256k/256k from 7 am to 7 pm and then 128/128k from 7pm to 7am. i want this only for the corporate clients.
i have tried setting 2 queues for the client by setting starting time on one from 07:00:00 to 18:59:59 and the second queue is set to 19:00:00 to 06:59:59
but it won’t take the timing for the second queue. i tried with 1d 06:59:59 but the router OS still won’t accept it. what am i doing wrong here?
please help me on this.
thank you
Niamul
Just add a second queue with no time and place it after the first one. If the rule doesn’t match with the first one, then it willl be applied on the other one.
niamul
October 8, 2009, 8:54am
3
Thank you
will test and get back to you
niamul
October 10, 2009, 4:24am
4
yes it worked.
thank you so much
dunga
October 10, 2009, 10:19am
5
niamul:
hello
thank you
Niamul
How did you achieve the above, cus i want to set bandwidth limting for my users, on hotspot and wireless.
the above can be achieved with simple queuing. In case you use HotSpot, you need to use scripts and scheduler to change the bandwitdh dinamically
dunga
October 11, 2009, 5:57pm
7
marioclep:
How do u set up the simple queue. I need a guide or a sample steps, then the script that will schedule and change the bandwidth dinamically
Either thru winbox or console command will be appreciated.
dunga
October 16, 2009, 10:38am
8
Can someone help me on setting up a simple queue for different people as quoted below.
niamul:
hello
thank you
Niamul
niamul, can send to me or post ur queueing script here let me try it as well.
