simple queue vs queue tree
if i have the same queue for the same ip address on both simple and queue tree which one surpasses the other or which becomes active or dormant?
Depends on your simple queue settings and priorities. The general consensus is you shouldn’t use both.
Yes, jwcn is correct, try to avoid matching the same traffic in both ‘queue simple’ and ‘queue tree’. What do you try to accomplish (all configuration scenarios might be accomplish without the mixing the same traffic in both queues).
