Does this limit all the communication of client on 192.168.1.3 to anywhere (to internet interface of the router?, to every other lan interfaces on the router?, to MikroTik router itself?)? If all is truth, am I able to limit only the direction to/from WAN interfaces with such simple queues?
OK that is what I expected. So now, if the queue will be full, it will also affect communication to DNS server directly on MikroTik router and other DNS server on LAN and or communication to local server on LAN which I do not want to limit. So what is the solution? I am thinking about one of these:
fastrack mentioned communication from LAN to LAN and LAN to MIKROTIK (incl. DNS?) and it will bypas this queue?
specify destination on queue (but there is an option for one interface only, not group of intefaces - I have 2 WAN)?
To all the other networks, as indicated in my previous post. Since your Server and that host are on the Same Lan ( same Network ) there will be no traffic limit between them …
( It can be limited, but that’s not the case here )
The RouterOS DNS service is running inside the router, you can see that as “a different LAN” in this context.
The only thing excluded from the Simple Queue (without further config) is the traffic being switched or bridged between ports that are configured in the same LAN.
However, it should not really matter. Under normal circumstances the queue will not drop much traffic, it will mostly just delay it a bit.
And when a user has saturated his queue with a lot of download traffic, he is probably not that interested in DNS traffic at that time.
No not “DNS as different network” but “inside router and outside on LAN as different network”.
EVERYTHING that passes through the router (and not only through the switch) is passed through the queue.
There is no need to do such settings (you cannot do that anyway), everything will work fine.
what would happen if the target is changed to an interface?
Would burst applied to each client going through this interface or is the traffic through this interface accumulated, means user 1 could consume all burst bandwidth if user 2 connects later.
