simple queue with time segment
Hi.
In a 2.9.51 x86 router i was trying to setup a queue that is active from 08:00 AM to 01:30AM of the next morning all days from monday to sunday, after 01:30AM it is supposed to be incative. I discovered that it doesn’t work. :frowning: If you set it to eg 08:00AM to 11:59PM (ie 08:00:00 to 23:59:00) it works fine…is after the 00:00 that the thing breaks up…
Do you know any solutions for this?? Is this a 2.9.x problem or is it in 3.x also?? I can upgrade the router to test this but it is a very production critical router so i don’t like to experiment..
