Simple Queue
I have read the wiki manual and followed the instructions for setting up a queue, but during my testing, it does not seem to be working.
Here is what I would like:
  • bandwidth limit for all traffic on wireless interface 1M/256K
  • burst to 5M down for enough time to trick speedtest.net into saying a 5M
Can someone show me a simple configuration for this? Please.
Alright, let me add more detail to my problems. I cannot get a basic,simple bandwidth limiter to work. If I run a speedtest, I get way too much bandwidth through my test connection (e.g. 50Mbit when should be 1Mbit). Why does this not work? What am I missing?
This is 6.0RC11
[admin@Mikrotik] /queue simple> print
 0    name="main" target=bridge1 parent=none packet-marks="" priority=8/8
      queue=default-small/default-small limit-at=0/0 max-limit=1M/1M
      burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
[admin@Mikrotik] /interface bridge settings> print
            use-ip-firewall: yes
   use-ip-firewall-for-vlan: no
  use-ip-firewall-for-pppoe: no
            allow-fast-path: yes
More info: If I look at the RouterOS speedtest (iperf?) on the link, it should the bandwidth being limited in one direction. But, if I simply run a speedtest to test servers, it tells me something completely different. If I disable the queue, the RouterOS speedtest goes up while the “real” test stays the same.
WHAT AM I MISSING???
