I’m having troubles activating simple queues with routeros 3.14 on RB600. The same configuration with routeros 2.9.50 on RB133 works.
Is there any bug?? Reading Roadmap there isn’t any trouble/improvement about this.
help… the same problem is going on with routeros 3.10 on RB4xx.
I did the same thing just the other day, it’s listed in the changelog
What's new in 3.12:
*) changed behaviour of simple queues - queues with no limit and type default-small
and no children actually do not get installed, as if there was no queue;
make sure your queues aren’t default-small
so - isn´t this issue already solved since 3.12, or how should i understand the changlog?
the issue still exists with default-small, or the issue is solved?
as i understand it´s solved till 3.12 and he is using 3.14
I’m confussed too, if the issue is solved in 3.12, why this behavior on 3.14.
However, i’m not working with default-small. Have you been test what you say, or it’s only a “reading” form changelog??
I’m currently using queues on 3.14 with no problems (using the ‘default’ type queue with both target-address and dst-address entries)
I posted the changelog entry because I know I missed it when I upgraded from 3.11 to 3.13 and didn’t realise why my queues suddenly weren’t working.
It’s not a bugfix, just a change in how the queues work.
