Simple Queues error(?)
Hi!
I’ve encountered the following “issue”: Clients are connecting to the router via a PPPoE connection. Every client receives an IP in the 192.168.151.x range. If I set up a simple queue for any of these IPs, for example, 5/5 Mbps, the speed still reaches 10 Mbps. If I set it to 2/2 Mbps, the speed goes up to 4 Mbps. What could be the issue? OS: 6.49.17, RB4011
I’m not running v6, but on the Mikrotik Wiki it says burst should be “0” for a default rule.
Maybe that’s causing you issues.
Also, you could check the rule statistics to see what the Average is
