simple queues, max limit on WAN interfaces
I need to set a max limit on interface WANA and interface WANB to keep latency from going up. I also want to be able to see each “cluster” on my network, each “cluster” or “pod” has up to 5 Vlans per. Below is what I have in place for the “pods”. Whenever I try to put a Max Limit on the target of interface WANA or WANB the rest of the queues will not work. Is there a way I can accomplish what I want to do? I cannot go into the queue tree while using pcc.
 0    ;;; Green Pod Start
      name="Green Combined" target=2049,354,387,347,2093 parent=none
      packet-marks="" priority=8/8 queue=default-small/default-small
      limit-at=0/0 max-limit=0/0 burst-limit=0/0 burst-threshold=0/0
      burst-time=0s/0s
 1    name="2049" target=10.255.14.0/24 parent=Green Combined packet-marks=""
      priority=8/8 queue=pcq_upload/pcq_download limit-at=0/0 max-limit=0/0
      burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
 2    name="354" target=10.255.9.0/24 parent=Green Combined packet-marks=""
 3    name="387" target=10.255.4.0/24 parent=Green Combined packet-marks=""
 4    name="347" target=10.255.3.0/24 parent=Green Combined packet-marks=""
 5    name="2093" target=10.255.15.0/24 parent=Green Combined packet-marks=""
 6    ;;; Blue Pod Start
      name="Blue Combined" target=47,21,287,241,317 parent=none packet-marks=""
      priority=8/8 queue=default-small/default-small limit-at=0/0 max-limit=0/0
 7    name="47" target=10.255.17.0/24 parent=Blue Combined packet-marks=""
 8    name="21" target=10.255.16.0/24 parent=Blue Combined packet-marks=""
 9    name="287" target=10.255.1.0/24 parent=Blue Combined packet-marks=""
10    name="241" target=10.255.12.0/24 parent=Blue Combined packet-marks=""
11    name="317" target=10.255.2.0/24 parent=Blue Combined packet-marks=""
12    ;;; Pink Pod Start
      name="Pink Combined" target=240,201,326,306,394 parent=none
      burst-time=0s/0s
13    name="240" target=10.255.18.0/24 parent=Pink Combined packet-marks=""
14    name="201" target=10.255.19.0/24 parent=Pink Combined packet-marks=""
15    name="326" target=10.255.10.0/24 parent=Pink Combined packet-marks=""
16    name="306" target=10.255.11.0/24 parent=Pink Combined packet-marks=""
17    name="394" target=10.255.8.0/24 parent=Pink Combined packet-marks=""
18    ;;; Red Pod Start
      name="Red Combined" target=488,416,452 parent=none packet-marks=""
19    name="488" target=10.255.5.0/24 parent=Red Combined packet-marks=""
20    name="416" target=10.255.7.0/24 parent=Red Combined packet-marks=""
21    name="452" target=10.255.6.0/24 parent=Red Combined packet-marks=""
bump,
could use some help. I have 2 100Mbps fiber connections that I load balance via PCC. I need to set a max download and upload on both the WAN interfaces. If they go much over 100Mbps the latency will jump to 500+ms. I also need to be able to watch the queues for each Vlan, is there a way to set this up via simple queues?
