Simple queues not Working migrating from 2.9.5 to 4.11
I’m beginners to Mikrotik, and i just upgrade my Router from 2.9.5 to 4.11
I’m using simple queue for limiting Bandwith, and after migrating my Simple Queue was unable to limit/track any traffic passing by from my Bridges/any interfaces.
I’v tried this script:
/interface bridge settings
set use-ip-firewall=yes
use-ip-firewall-for-vlan=no
This script run succesfully no errors, but has no effect to my Simple Queue traffic…
Someone can help me to makes my Simple Queue to running well again on 4.11 ?
Really Appreciate your Helps & Thank You
Anyone could help me here… ???
My network stuck, the thread only can be used by 5-8 workstation who can get Internet connection:( , so other workstation must wait…
Thank You
Post your simple queue configuration. It’s hard to say what is wrong with them without seeing them. Also post your IP addresses, routes, firewall mangle rules if you use them, and a network diagram.
Thank You fewi,
I’v found the problem that my queue type was pfifo
Now my simple queue is working normally :wink:
RouterOS 4.11 often disconnected from winbox-2.2.15, but not hang/glitch only disconnected… and then i can reconnect again directly
Regards
