Simple queues not working?
Hi All,
I’ve got an RB750GL running ROS 6.1, freshly set up out of the box. At present it’s a very simple set up:
ether1 - attached to an ADSL modem, RB is doing the PPPoE authentication for the ADSL, IP address assigned dynamically.
ether2 - attached to the LAN on 192.168.1.0/24.
My problem is that simple queues are not working at all. I’ve even created a catch-all queue for the whole network, like so:
add name=rest-of-network priority=7/7 target=192.168.1.0/24 total-priority=7
When I run torch with 192.168.1.0/24 as the source and 0.0.0.0/0 as the destination (on ether2), I see all of the traffic, it just appears that the simple queues are not picking this up.
I’ve got simple queues set up at work on our CCR1036 and a clients RB450G and it seems to work fine, it’s just this one instance where I can’t get it to work! Am I missing something?
My whole config (sanitised) is as follows:
set 0 comment=WAN
set 1 comment=LAN
/ip neighbor discovery
set ether1 comment=WAN
set ether2 comment=LAN
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add name=dhcp_pool1 ranges=192.168.1.50-192.168.1.200
add address-pool=dhcp_pool1 disabled=no interface=ether2 lease-time=1d name=dhcp1
/ppp profile
add change-tcp-mss=yes name=Xilo-ADSL only-one=yes use-mpls=no
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 max-mru=1432 max-mtu=1432 name=OMITTED password=OMITTED profile=\
    Xilo-ADSL use-peer-dns=yes user=OMITTED
set Xilo-ADSL discover=no
/queue simple
add name=vuplussolo2-livingroom priority=1/1 target=192.168.1.3/32 total-priority=1
add name=skyboxf5-bedroom priority=2/2 target=192.168.1.4/32 total-priority=2
add name=ps3-craigsroom target=192.168.1.6/32
/system logging action
set 3 remote=192.168.1.5
add address=192.168.1.254/24 interface=ether2 network=192.168.1.0
add address=192.168.1.0/24 dns-server=192.168.1.254 gateway=192.168.1.254
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add chain=forward comment="Allow LAN interface to anywhere" in-interface=ether2
add chain=forward comment="Allow established traffic to/from anywhere" connection-state=established
add chain=forward comment="Allow related traffic to/from anywhere" connection-state=related
add chain=forward comment="Allow TCP Port 5001 to Synology NAS" dst-address=192.168.1.5 dst-port=5001 protocol=tcp
add action=drop chain=forward comment="Drop invalid traffic to/from anywhere" connection-state=invalid
add action=drop chain=forward comment="Drop everything else to/from anywhere"
add chain=input comment="Allow LAN interface to router" in-interface=ether2
add chain=input comment="Allow OMITTED to router" src-address=OMITTED/29
add chain=input comment="Allow established traffic to/from Router" connection-state=established
add chain=input comment="Allow related traffic to/from Router" connection-state=related
add chain=input comment="Allow ICMP PING to router" protocol=icmp
add action=drop chain=input comment="Drop invalid traffic to/from Router" connection-state=invalid
add action=log chain=input comment="Log everything else to/from Router" log-prefix="FW INPUT"
add action=drop chain=input comment="Drop everything else to/from Router"
add action=masquerade chain=srcnat comment="NAT Outbound LAN Traffic" out-interface=Xilo-ADSL src-address=192.168.1.0/24
add action=dst-nat chain=dstnat comment="Forward TCP Port 5001 to Synology NAS" dst-port=5001 in-interface=Xilo-ADSL \
    protocol=tcp to-addresses=192.168.1.5 to-ports=5001
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip proxy
set max-cache-size=none
/ip service
set telnet disabled=yes
set www port=8000
set www-ssl port=8443
set api disabled=yes
/system clock
set time-zone-name=Europe/London
/system ntp client
set enabled=yes mode=unicast primary-ntp=129.67.1.160 secondary-ntp=129.67.1.164
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
If anyone could shed some light on this problem I’d be most appreciative.
Thanks,
Verta.
Janis (mikrotik) said that this fixed in version 6.2
Regards.
Dzieva.
Thanks for that, I’ll downgrade to 6.0 now and wait for 6.2.
