Simple queues, total counters
When I setup a simple queue using PCQ, the total counters do not increment.
PCQ download and upload are OK. The queue functions correctly.
With default-small for the total, the counters remain blank. But, set the total to default and the counters start working. Very odd.
Is that the correct setup for a PCQ simple queue?
I use a parent queue of the same type with all bandwidth settings set. Then direct the child to the parent. Is that correct or should I have the parent set to unlimited and only set child bandwidth limits?
It would make sense to have parent and multiple child simple queue with differing settings or even have the parent set to unlimited and the single child set to my connection limit. Any ideas here?
Many thanks
yes it is true
