Simple Queues very reduces throughput.
When rules in Simple Queues no - RB750 has a WAN->LAN - 100 Mbit/s. CPU-30-40%
If I add at least one rule Simple Queues, the maximum speed WAN->LAN is reduced to 45-50 Mbit/s. CPU - 100%.
Also it is established in Simple Queues MAx Limit Upload/Download = 100Mbit/s.
Although the Simple Queues rule set not even for my local IP-address.
Why?
Tested on speedtest.net
I use Dynamic IP. fiber.
Your device is way too slow to handle that speed with simple queues, you could try queue tree but I doubt that it will help that much…
I’ll try queue tree. but I doubt…
Here I think the problem is inefficient algorithm Simple Queues.
