None of the values seem to have any affect on the Interface.
The interface IK is part of bridge1, if that makes any difference
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none interface=
“IK” path-cost=10 point-to-point=auto priority=0x80
Microwave path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 disabled=yes edge=auto external-fdb=auto horizon=none interface=
ether3 path-cost=10 point-to-point=auto priority=0x80
ether4 path-cost=10 point-to-point=auto priority=0x80
ether5 path-cost=10 point-to-point=auto priority=0x80
set “IK” vlan-header=leave-as-is vlan-mode=fallback
set Microwave vlan-header=leave-as-is vlan-mode=fallback
set ether3 vlan-header=leave-as-is vlan-mode=fallback
set ether4 vlan-header=leave-as-is vlan-mode=fallback
set ether5 vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
ROS 5.6
EDIT: Looks like it might be a bug in ROS 5.6? But how do I upgrade? In the 4.x series you just uploaded the new file. I can’t find such a place on the 5.x routers, and this router doesn’t have Internet access.
I have tried this once some years ago and it worked.
I am not sure if the queue would capture traffic from your interface
since it is encapsulated in another interface, which is “bridge1”.
Try if the queue works if you specify:
interface=bridge1
as for upgrading/downgrading, of course you can. Just upload the files
in the File window using winbox. It should be there.
Yeah… I was trying to do it without WinBox (I use a mac). Finally found the dialog box… ugh.. nice new UI… but changing the upload from upgrade took a while to find.
I upgraded to 5.12 and tried both the interface and the bridge. No difference. Then I tried the IP of the computer on the interface I’m trying to limit, still no change:
I just created one simple queue where I specified as target interface
the ether2 interface on my RB750 which has the latest version 5.12,
and is working:
I’d be glad not to bridge – if MikroTik supported SNMP graphing of switched interfaces! That’s THE only reason I bridge. If there was some way to stay switched every MT switch in my network would be switched only.
