This is an question already posted here, by Wyoming, and not aswered yet.
I use Mik 2.9.11 and I have the same problem.
… We use Simple queues to traffic shape all our customers. This all has been working fine except for one customer we just found. We set up rules for each customer and then for all our equipment. Then at the end of the queues we set up a catch all queue to catch any other traffic so that our customer can’t pick a different unshaped IP in the block and get more speed.
The problem that I am seeing now is that the customers traffic is now hitting the queue for their traffic and then hitting the catch all queue. We have this same setup in 20 other Mikrotiks and they are all working fine.
My understanding was that the first rule should catch all traffic and the exact opposite of that traffic. Can someone help me understand why this is not working here but it is working for all our other sites.
we are using 2.8.17 at this time. I may need to upgrade but I didn’t see anything in the change log that indicated a problem with simple queues being fixed…
Your catch all rule will have to exclude everything that is queued already. The queue tree does not exit on first match, it matches through the entire list - therefore, 0.0.0.0/0 obviously includes the address-lists that you have specified in the previous queues
Someone else might have a better solution, but I’d suggest not using a simple-queue for the catch all. Mark the packets, and do your queueing based on the marker, not the ip address. Then you can use your catch-all to mach all packets that is not already marked.
Wow, this topic dates way back with me! I never got MikroTik to understand the importance of the “Default Bucket” or “Catch All” function a year or more ago. This is a relatively simple function that our Packeteers performed very well.
Gevasio hit it right on the head…we need a way to limit any and all traffic not already assigned to a Simple Queue to eliminate the chance of available IP addresses from being used without authorization.
well, of course it will catch everything, please read the manual on how simple queues are placed. as for the solution, you should specify some classifier, be it source, destination address or interface for the “catch all” queue to catch the traffic it is supposed to catch.
