Simple Queues
Hey, I am trying to create a Bandwidth Throttler router using a MikroTik. I have been digging through the forums trying to find an answer and have yet been able to come up with one. The problem that I am having is that traffic is not getting to the Queue. This used to work in 5.x and it does not now. I know there have been changes in the queuing in 6.x but I have not been able to find the answer that I seek.
Here is my config script that I had pulled from the router in question. Any and all help would be greatly appreciated. Thanks!
# jun/02/2014 10:11:31 by RouterOS 6.12
add l2mtu=1598 name=SpeedControl
set [ find default-name=ether1 ] name=eth01-WAN
set [ find default-name=ether2 ] name=eth02-Customer
set [ find default-name=ether3 ] name=eth03
set [ find default-name=ether4 ] name=eth04
set [ find default-name=ether5 ] name=eth05
set [ find default-name=ether6 ] name=eth06
set [ find default-name=ether7 ] name=eth07
set [ find default-name=ether8 ] name=eth08
set [ find default-name=ether9 ] name=eth09
set [ find default-name=ether10 ] name=eth10
set [ find default-name=ether11 ] name=eth11
set [ find default-name=ether12 ] name=eth12
set [ find default-name=ether13 ] name=eth13-MGMT
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
/port
set 0 name=serial0
set 1 name=serial1
/queue simple
add burst-time=30s/30s limit-at=34M/34M max-limit=35M/35M name=Customer target=eth02-Customer
add bridge=SpeedControl interface=eth01-WAN
add bridge=SpeedControl interface=eth02-Customer
add address=172.31.10.94/28 interface=eth13-MGMT network=172.31.10.80
add distance=1 gateway=172.31.10.81
/ip upnp
set allow-disable-external-interface=no
Still having this issue. Any help would be appreciated. Thanks!
/interface bridge settings set use-ip-firewall=yes ?..
That was it.
Thanks!
