Simple Queues
Is there any way to improve on the way I am doing my traffic shapping?
Lets say I want to limit a block of addresses,
I currently create a simple queue for each address in the block of addresses, (which is usaully hundreds) and I create them using a script.
Is there any way I can shorten this up, say in one simple queue, utilizing an address list or something simular?
Thanks,
Dan-
pcq?
Ahh excellent, I dont remember seeing that in the manual..
Any examples for setting it up?
Thanks!
dan-
Ok, I see alot of posts on the forum about PCQ,
but I still have one question:
I have a group of IP’s, I want to give each user a set amount,
say 1000k x 1000k
Will PCQ do this? I dont want all users sharing a “bandwitdh pool” I want them all gauranted the same.
Thanks,
Dan, PCQ allows to accomplish requested scenario.
Configuration example,
http://wiki.mikrotik.com/wiki/PCQ_Examples
Ok, I wanted to make sure pcq didn’t pull from a “parent” bandwdth.
Thanks!
dan-
please can u send us tht script
thnks in advance
Reagrds,
:for i from=2 to=254 do={/queue simple add target-address=(x.x.x. . $i . “/32”) max-limit=up/down}
replace up and down with your rates.
replace x.x.x with your ip’s
Example
target-address=(10.10.10. . $i . “/32”)
when put in the above statement,
will create simple queue for 10.10.10.2 through 254
-dan
