simple redirect
I have been using osbridge AP’s and its onboard hotspot controller chillispot to redirect traffic to a third party hot spot controller.
I have started using Mikrotik Ap’s and want to achieve the same. I dont want to use the MK Hotspot functionality, just have wired or wireless clients get redirected to a specific public IP address for authentication, then resume normal traffic.
Any assistance to achieve this would be greatly appreciated.
Uinsean.
This can be done easily with Mikrotik RouterOS, as far as I understood, you want to redirect your users to a login page, hosted on some external server instead of Mikrotik itself. If I got you right.. see this: http://wiki.mikrotik.com/wiki/HotSpot_external_login_page
Anyhow, you’ll require to setup hotspot on MT box & make required changes into the login.html in Hotspot directory of MT.
I hope it helps!
Rahul..
Got it now.
Thanks for your time.
