I’ve searched around and followed tutorials but I just can’t seem to get a simple route working.
I have one Mikrotik RB411 set as AP Bridge(10.0.0.4) > Mikrotik RB411 set as Pseudobridge using WPA2.
Wireless link between the two works great.
Access Point Bridge
Wlan & Ether Bridge - 10.0.0.4
Client (Pseudo bridge)
The WLAN interface has IP of 10.0.0.69. Ether has IP of 192.168.22.100
I would like to use routing instead of bridging, so I just can’t get the two subnets to communicate with each other.
I’ve also set up the src nat masquerade function, but nothing seems to work…Just need a little help.
That’s what I’ve tried but for whatever reason it doesn’t seem to work. Perhaps If you don’t mind, give me instructions on exactly how to do it because I must be doing something wrong.
interfaces on the Client are not bridged…the weird thing I just discovered is if I open up a terminal window on the client computer I can ping the gateway IP of the AP but I can’t browse the net or ping a website. I also can’t ping the gateway from the ping option in winbox on the ether interface.
