Simple script for resetting hotspot limits?
What would be the easiest way to reset the limits for hotspot profiles/users on a monthly basis? I don’t need any complicated billing on anything. Just something simple…
Any ideas? I’ve searched around on the forums, and most things either seem to range from way too complex (I just have 3-5 users with a very shared VSAT connection, just want to control how much is downloaded) or too old.
I have an RB 750. I’m not sure what version of Mikrotik OS it has on it.
Thanks in advance.
Edit: I want to reset the limits, not the users themselves.
/system script add name=remove source={/ip hotspot user  {:foreach a in=[find ] do={remove a}}; /ip hotspot {profile {:foreach b in=[find default=no] do={remove b}}}; :log info "HOTSPOT USER REMOVED";}; /system scheduler add disabled=no interval=4w2d name=runscript on-event="/system script run remove" start-date=feb/09/2012 start-time=00:14:49
Make sure clock is correct
And this will reset their data limits? Sorry, maybe I should have been more clear about that…
Edit: After looking at your script more closely, I think it only removes the users, not their limits. I might try to use the script to remove their limits. I’m just not exactly sure how to do that.
Any ideas on how to do that?
Thanks for the response though.
Samsung, your reply was blank…
