Simple single-line script to schedule
I simply want to create a single script that does this.
/queue simple set 11 1M/4M
But instead of using the ‘11’ I would like to use something like [find target=192.168.88.25]
I don’t know what it is but I’ve tried a variety of variations on replacing the “11” with the phrase I have in brackets and I’m not sure why it doesn’t run.
I’m sure someone will know right away. Thank you in advance.
Kevin
This is how you do it:
/queue simple set max-limit=1M/4M [find where target=192.168.88.25/32]
PS you need to specify subnet mask /32 for the IP, even if WinBox does not show it on single IP.
You can see what IP are used when typing
/queue simple export
add max-limit=1M/4M name=test parent="Bandwidth Control" target=192.168.88.25/32
If IP does come from a variable:
:local IP "192.168.88.25/32"
/queue simple set max-limit=1M/4M [find where target=$IP]
or
:local IP "192.168.88.25"
/queue simple set max-limit=1M/4M [find where target=$IP."/32"]
